Control Valve Question
Chuck_17
Member Posts: 148
Quick control valve question:
Is the close-off pressure the max differential across the valve (as I have always assumed) or is it the water pressure at the valve?
Differential
The issue is against what differential pressure the valve can hold closed.
The net water pressure at the valve has to do with the valve body and assembly rating."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
