Control Valve Question
Chuck_17
Chuck_17 Member Posts: 148
Quick control valve question:
Is the close-off pressure the max differential across the valve (as I have always assumed) or is it the water pressure at the valve?
  • Brad White
    Brad White Member Posts: 2,399
    Differential
    The issue is against what differential pressure the valve can hold closed.
    The net water pressure at the valve has to do with the valve body and assembly rating.
    -Ernie White, my Dad
