pex tubing insulation
Brad White_9
Brad White_9 Member Posts: 2,440
split of course :) and as tight as I can get to the OD of the PEX. I specifed it for the homeruns on buried PEX in a radiant floor at Williams College to keep the interior from overheating. Works fine, barely a degree up from the surrounding untubed floor, last I measured.
  • doug o'connor
    doug o'connor Member Posts: 17
    what is the best insulation to use on pex tubing?
    areas that are not to be heated.
  • Weezbo
    Weezbo Member Posts: 6,231
    couple ideas,...
    one is put the tubes through a much larger tube and insulate that pipe.
    insulate with 1" split foam and spray foam that...
    i let some other people answer then you get conformation or other techniques... *~/:)
  • > one is put the tubes through a much larger tube
    > insulate with 1"
    > i let some
    I just use 1/2" wall split foam sized to the tube. Seems to work ok.
  • I just use 1/2" wall split foam sized to the tube. Seems to work ok.
  • Tim P._2
    Tim P._2 Member Posts: 47
    I just used tubolit split foam. I also used armoflex when I thought about insulating the pipe prior to making the connections up.
    I believe it's the same ID as copper, eg 1/2 pex requires a 5/8 ID insulation.
    As an aside, if you use the 3/8" thick foam, you can insulate pex that is suspended by pex rails without much trouble.
    Tim
  • hr
    hr Member Posts: 6,106
    Exposed? or in the walls?
    seems the foam type breaks down after a few years in sunlight or UV. If it is exposed and you want nice looking I use the Techlite brand. www.techlite.net Available in many jacket types and colors.
    In walls, crawl spaces, etc I buy the unsplit style Armaflex or other brands and slide it on as I unreel.
    Actually straight lengths of pex or PAP are much easier to insulate and handle. Most radiant manufactures offer 20 foot sticks, these days.
    hot rod
