gas \"plug\" valve question
oil-2-4-6-gas
oil-2-4-6-gas Member Posts: 641
thats the problem non of my suppliers have any --and no one knows what type of grease/lubricant it is trying to get this taken care of --like yesterday --
  • oil-2-4-6-gas
    i was working at a waste water treatment plant today had to replace 2 2-1/2" motorized gas valves -any way it turns out the plug valve before the regulator is leaking --i capped it the valve is Huber ty i want to replace it but there is nothing to shut off before the meter -8" main --not doing this 1 on the fly --my question is -this plug valve is a grease seal -- i need to know what kind of grease is used for Natural gas ---
  • Blackoakbob
    Blackoakbob Member Posts: 252
    sealant/grease
    oil-2-4-6-gas hello,
    I have in my hand a box of Rockwell Sealant No. 386 Size C. This what I use. Can be purchased where you buy your lubricated plug valves. If this size is to large ( 2inch long by 1/2 diameter) you can roll it in your hand like putty to thin it out.
    Best Regards,
  • Ed_26
    Ed_26 Member Posts: 284
    lube
    Did you try your utility? Their riser valves are usually "luboseal" type valves.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Plug valve lube
    Do you have a Ferguson in your area? they should be able to get it.
    jim
