Clamp-on fin for 1 1/4\" pipe
Paul Pollets
There are no replacement fins available. Element only with fins can be puchased, but system must be drained down to replace the sections of pipe. Not quite a DIY job.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Can I get clamp-on fin for 1 1/4\" pipe?
I have a hot water heating system. A lot of the fin is missing from the baseboard heat. Does anyone know where I can purchase clamp-on fin for 1 1/4" copper pipe? Thanks!0 -
It may be "missing" on purpose if the heat calcs for that room only called for a certain amount of radiation then the rest of the pipe behind the cover would be left blank intentionally.0 -
clamp on finn's
Paul,I have seen some clamp on fin's for 1 1/4" and 1 1/2" steel many years ago...Big thick aluminum fin's they were...0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
