I like things simple.......hb
hr
Member Posts: 6,106
to see your work and smiling fonts :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
because I am simple.
We installed this Vitola this week in one of the large homes over by Lafayette College. 3.5" mains with lots and lots of cast iron. No condensing boilers, mixing valves, controls or anything other than a great boiler. Although, we did do some P/S piping.
Simple and efficient. I like simple.There was an error rendering this rich post.
Nice.
Nice, clean job hb. Keep it rolling! -DF
Nice!
Jeff you rock! Can't wait until we can get together again. I hope you are going to Vegas for HCT.
John Jr.0 -
Simple small job yet you still used that shiny diamond plate. Youry work always has a special neatness to it.
Leo0 -
Great Work!
That Vitola looks like it has been plumbed to the manufacturers specs, is happy, and it should keep the homeowners happy for years to come. Did you bother with a Vitotronic 200 or is the simpler control "good enough" for this application?0 -
hb
simple, clean, neat
Great Job!
Robert O'Connor/NJ0 -
Even your simple jobs
come out looking fantastic . That Viessmann looks like one heavy duty piece of equipment . Does it have a propietary burner ? Easy to work on ? Nice change of pace from the beautifully complex artwork you usually work on , huh ?0 -
Awesome!
Awesome job! It looks more like a piece of art than a boiler. After seeing all the retarded piping and wiring, it's nice to see that someone is putting the time and effort in to make things look that good.0 -
Only one teensy-weensy question
But why is it in the basement?
Such a beauty deserves to be sitting in the middle of the front parlor, with little doilies on top...
Well, I'm sure most of you understand.
Thanks for posting the photographs.0 -
That's one of the best-looking installs I've seen
keep it up!0 -
That is The way to go. *~/:)
clean.0 -
Simple is
as simple does !
Uhh I think
Nice job Pal.
Clean and sweet. Nice to see you around.
Scott
No 200............
just the KK10. The P/S piping allows the system to mix water temps, so it, sort of, self regulates upon demand. The boiler rise is at 30° while the radiators maintain a much tighter more even temperature this way. I may install two stage stats at some point to further enhance comfort and save more fuel. We'll see.There was an error rendering this rich post.
My life is like...........
a box of chocolates........... ;-)There was an error rendering this rich post.
Definitely like the change, Ron.
We have a couple of radiant projects going, which never seem to end, so I am enjoying this in and out stuff. You would probably have this done by lunch!
Yes, the gas burner is proprietary to Viessmann and pretty easy to work on. After installing quite a few condensers, I forgot just how big (and heavy) the Vitola actually is! Still my all time favorite boiler, though.There was an error rendering this rich post.
I have to agree
For a lot of applications, even a condenser has a tough time beating a Vitola. One can also bet that given anywhere near decent care, that boiler will still be there in 40-50 years.
We're in the same situation right now Jeff. 7,000 sq ft house with 6,600 ft of snow melt. Seems like we've been at it for 2 months and it's only been two weeks. Trying to get all the outside work complete before snow happens.
Nice work, as usual!0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
