Fractional drill bit for 1/8\" pipe tap
Steamhead (in transit)
Member Posts: 6,688
For the 1/8" NPT tap is "R". There are several drill index sizes...(1) Fractional, the most common, (2) Number sizes 1 thru 80, with 80 being the smallest (3) Letter sizes A thru Z. "A" size begins where #1 size leaves off. The letter and numbered size drills "fill in the gaps" between the common fractional drill sizes, and are known and used in machine shops. The lettered and numbered drill sizes are also used to size orifices for gas burners to control the amount the gas output at a known pressure.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
What is the size to lead a 1/8" npt pipe tap? I received something of a letter equivelant "R" which I have no clue about.0 -
I think it is \"Q\"
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
it is a
11/32" drill bit, but i don't know off the top of my head about the tap size and i dont feel like running out to the truck to check mine. if you dont have an answer for the tap by tomorrow i'll post it for you here.0 -
ok i did run out to my truck to check
it is a w-r 1/8"tap0 -
Thanks guys . . very informative!0 -
drill size
R drill is just a tad under 11/32" thats what I use with no problems0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
