troubleshooting low-pressure steam system for higher than normal
Bruce Gorvett, Custodian, Trinity United Church, K
Member Posts: 1
I am troubleshooting our low-pressure steam system (fire tube boiler) for source of much higher than normal gas consumption. Could you give me some feedback on what to look for?
One thing I have been doing different this season from previous times is setting the thermostat down only 2degrees overnight instead of the usual 7-8.
Other problems may include steam leaks, faulty traps,--- I am hoping you have other suggestions as well.
Thank You,
Bruce Gorvett
Thank You,
Bruce Gorvett
First
Fix all the steam leaks. LEAKS keep the burner running longer and would start sooner .
Have the boiler checked out burner and boiler tubes may need cleaning.0
- 167 Indoor-Air Quality
