Crappy Honeywell controller
It was 3yrs, 4 months old. Totally dead, no lockout, no light,etc., not in excessive heat situation. at least my wholesaler did me right on the price, and the instructions are priceless. i need to learn about the EnviroCom system one of these days.
  • Dave T_4
    Dave T_4 Member Posts: 5
    I have had to replace the Honeywell (R8184G) controller on my oil burner every 12-14 months for the past few years. Seems to me these should last longer than that. Any suggestions on a more reliable unit?
  • They are
    usually a pretty reliable relay, do you have any idea what part of it is "toasting" on you?
    Dave
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    What is the problem?
    The R8184G is an older design, and is being replaced by the R7184, but is a very reliable control. They can fail if they get wet, or are physically damaged, but failures as you describe are rare. What did you do with the "dead" controls? Can you get me a date code? (4 digit number) stamped on the control. Are you a contractor or a homeowner?
  • Dave T_4
    I am the homeowner, first off. As for the date codes, I can only give you that for the latest unit which failed, which is "0528". I don't believe the unit got wet or was otherwise damaged. I think this controller was perhaps 18 months old, going only by memory. Looking at the unit both inside and out, you would swear it was brand new.
  • BillW@honeywell
    That unit was built in 2005...
    and the warranty has expired. When you say it failed, what happened? Who determined that it was the oil primary that failed? Have you had a trained contractor check the rest of the oil burner? What brand of burner is it? There are many components that interact with the R8184G primary to make your system operate safely, and any of them can cause problems. Doesn't your oil supplier provide a yearly service plan?
  • MikeB34
    MikeB34 Member Posts: 155
    what appliance are your working on
    Some furnaces used a R8184N. I have had this issue crop up and it is usually some monkey replacing the N series with a G. The N has a larger transformer, and using the G will cause it to burnout VERY quickly.
    Check with the manufacturer of the appliance, or if you have a parts list if it shows the unit with a R8184N.
    Mike
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    roll call
    I committed that felony myself. Wasn't looking and it was 9:30pm-late service call.
    I haven't really had too many issues with the Primaries from Honeywell. I do remember working in my own house once and I spilled my coffee all over it. It was summer and I figured I would get to it before fall. Two months later the cold weather came and I forgot to replace it (you know the whole shoemaker thing) now 4 years later still going strong.....Caution that was in my own house- if it was a customer it would have been replaced asap. My poor family.....
    Cosmo
  • Darrell
    Darrell Member Posts: 303
    If the burner door, (the plate the burner mounts to), is not insulated like it was originally, the 8184 will not last very long...it tends to cook. The ignition transformer won't last either.
  • william_5
    william_5 Member Posts: 62
    Some thing not to be over looked
    Any time you are toasting relays time after time. I have found a bad ground, that is coming in from the pole, the water pipe or the ground rod
    William
  • Mitch_4
    Mitch_4 Member Posts: 955
    sorry Cosmo
    Didn't mean to imply you were a monkey..;-}
