Indirect water heaters
ALH_4
ALH_4 Member Posts: 1,790
I would choose the Triangle Tube tank. Amtrol coils have a design that is very inferior to the Triangle Tube tank-in-tank design.
  • Oney
    Oney Member Posts: 5
    A little help...
    Checking to see preferences on either Triangle Tubes Smart series indirect or Amtrol's Boilermate indirect heaters.
    Anyone have a history with either of these units?
    Thanks
  • laurence salvatore_2
    laurence salvatore_2 Member Posts: 86
    Stay away from both. Tha Amtrol is primative and too expensive for what you get. The Triangletube's controls last about a year if fortune smiles upon you. Crown Megastore, Superstore with 1" coil, Vaugh, are all makes I have used and use. Amtrol and Triangletube are makes I seem to fix or replace.
