leaks
BigRed
Member Posts: 104
I use about 8 feet of pipe wrench, a 36" wrench with a big pipe slid over the end , I dope the female threads and I use a teflon thread to fill the male threads then tape then dope only white permatex it also helps to have some big guys on hand to work the wrench,
4\" tappings
Have any of you guy's had problems with water tight connections at the boiler?
We have been chasing our tail lately with this.
The larger 4" and 6" supply tappings seem to be giving us fits. This is on intial fill up and hydrostatic tests with out any heat being applied.
We intalled a couple of H.B. Smith 28-7's that wouldn't cooperate. Finally we used a permatex sealer made for the automotive industry. That stopped it, but I doubt it will ever come apart.
It doesn't seem to be unique to Smith. We had the same problem with Burnham and Weil.
Keith0 -
LEAK PREVENTOR
any water connections including steam systems below the water line use lampwick [ quickwick ] and joint compound & presto ----NO LEAKS. old , bad , or damaged threads----wick & permatex. case closed0 -
As JCA says
Dope, Tape, Dope !!
I agree. we have alittle problem getting the youngsters to understand but its the Best way to eliminate leaks on the boiler piping !
Scott
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
