Need Pro in or near AURORA, IL
Bob W._3
Member Posts: 561
Eric, did you call Glenn Harrison at Jett's in McHenry, to see if he could either help or refer you to someone?
Two-Pipe System Needs Major Work
I need a pro to work on the two-pipe steam system in my 1917 home in Aurora, IL.
After discussing the problems with my steam system here on The Wall, I've got a pretty good idea I need the following work done:- Repiping all around the boiler
- Venting and dripping the main
- Fixing or replacing failed traps
The main is a big loop that needs to be split, vented and dripped to the boiler, about 20 feet away. I've got 8 radiators, a mix of 5-pipe with 8C traps and 3-column either without traps or with old elbow-looking ones.
The boiler, a Burnham I8N, is currently set up with only one of the two pipes coming out of it; the other is capped. There isn't a Hartford loop (took me a while to realize this).
You can see pictures and find other details on this thread.0 -
Isn't it amazing
that we don't have more professionals choosing to list their companies in Find a Professional?Retired and loving it.0 -
Williams Stoker
I've received good service from Williams Stoker Co. They're in Chicago, on Belmont Ave. I don't know if they go out to Aurora but they could probably recomend someone.0 -
I haven't been able to find a listing for either Glenn Harrison or Jett's in McHenry or anywhere in the region. Do you have any more contact information?0 -
Eric, also try Dave \"Boilerpro\" Bunnell
His company is Boiler Professionals, in Amboy which is to the west of Aurora. Either Glenn or Dave should be able to fix you up.
If you can't find them any other way, get their numbers from directory assistance.0 -
Dave and I had a great chat about the steam system this morning. He's clearly the man for the job. Unfortunately, he won't be able to come out this way for several weeks, possibly not until December.0 -
A classic problem
The good guys are busy and you have to wait. The bad guys are available to do the job yesterday but you don't want them.0 -
I'm here.
Eric, if you wish, you can call my boss, Wayne Jett, owner of Jett's Heating and Air, at 815-276-5951 to discuss this further. Please be aware that we are based out of the city of McHenry IL, located in northern McHenry County. I believe we about 1 to 1 1/2 hours away from Aurora.
I don't want you to be misled, so I will say that I have some experience with steam heat, mostly maintenance and service of the boiler itself. I however do have a high work ethic, I love to do things right, even if it involves research to make sure it is done right. I have to say Dave is your best bet, but since he is so busy, (no surprise there) I would not have a problem with checking out your system further, of course with permission from Wayne.
Please forgive me as I don't have the time to browse your previous post at this moment. However, I will try my best to read it over in the next day or two to get a better idea of you needs.
Thank you for your consideration.
Glenn Harrison, Service Technician.
Jett's Heating and Air, McHenry Illinois.0 -
Bob W
Thanks for throwing my name out there. Greatly appreciated.0 -
How nice it would be
if you guys had Find a Pro ads. Good for you, and good for HeatingHelp.com.Retired and loving it.0 -
Agree
I for one would use the anology this site compares to going to Mayo Clinic. Any other doctor is just a quack. I'm located in northern, ILL. No one pops up in a 75 mile radius in find a proffesional. Boiler Pro, do you know Jack King, Jack Skully, or Greg Liebing of Amboy? We all use to work together. Small world !
Gordy0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
