new heating piping
in a new installation of heating , reverse return piping , does the supply pipe as to be install at level or going upsteam to end
  • JackEnnisMartin
    JackEnnisMartin Member Posts: 70
    piping orientation
    Mr Roy
    I would suggest { no criticism intended } that you avail yourself of one of the heating contractors in your area. I would suggest your question is one that indicates you are not at all comfortable with heating installation and I can see only problems for you doing this work yourself. Heating is not nor will it ever be a " homeowner -- handy persons" area to be working in.
    Good luck and please get a contractor
    Jack Ennis Martin
