new heating piping
stephane roy
Member Posts: 1
in a new installation of heating , reverse return piping , does the supply pipe as to be install at level or going upsteam to end
piping orientation
Mr Roy
I would suggest { no criticism intended } that you avail yourself of one of the heating contractors in your area. I would suggest your question is one that indicates you are not at all comfortable with heating installation and I can see only problems for you doing this work yourself. Heating is not nor will it ever be a " homeowner -- handy persons" area to be working in.
Good luck and please get a contractor
Jack Ennis Martin0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
