Radiant
Kevin A Gerrity_2
Member Posts: 27
His is my own home and my office is in the basement. I have radiant foors above with joist trac. The floors are insulated 5-1/2" would this cause any problems.
Radiant oven cement floor
Has anyone ever installed radiant floors on top of a cement basement floor? What are the do's and don'ts.0 -
getting an insulation layer
is the biggest challange. Ideally an inch of foam board would be a plus. But by the time you get insulation, tube, and final flooring you might be up a couple inches. This could be an issue with any doors, and of course the first stair riser will be way off
Consider ceiling radiant. Almost the comfort level of floor, and sometimes less of a retrofit hassle.
Do a heat load calc first, of course, but basements are not generlly hard to heat.
hot rod
Roth Panel
You might want to look at Roth Panel. Low profile 3/4" think and has high density foam built into the radiant panel. Very efficient and comfortable. Floor cvering can be challenging, BUT if you choose a floating floor material, you will love the product. Make sure you glue it down with a foam compliant adhesive.
http://www.roth-usa.com/usa/pdf/5A_RadiantPanelManual-Sep04.pdf
Jeffrey0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
