New Install
HitzKup_2
Member Posts: 45
http://www.contractormag.com/articles/newsarticle.cfm?newsid=1159
Latest New Boilers Install
This is our lattest new boiler room. We have there 2, Larrs Pannant boilers, 1,000,000 btu input each, 2, Apollo ATC Mixing Valves, 34HL series, 2 Turbomax model# 109, 2, Cash Acme 160 gal. expansion tanks, 1, 4" Caleffi hydronic Separator. We are supplying hot water for 14 Showers. 3, fan coil units, 2, heating coils for Mikva pools.0 -
Hi Moses
Wow,, i had to keep checking to see if those pipes were sweated, thats a fine looking job!! very neat and professional looking!!!
David0 -
Brilliant... just Brilliant...
More of a Mitzvah than a Mikva
I presume that the "W" shapes are for thermal expansion or for fluid mixing? Nice touch. It will be a shame to insulate it.
You probably get this all the time, but, "are you going to go back and solder the joints now that you set them up dry so nicely?"
Stunning work!0 -
The solder joints are done by passionate mechenics, who take pride in thier work.
Moses0 -
looks Like a Take *~/:)
Nice WORK! that must be quite a few man days into the work....i like your trust buh verify gages:)0 -
It Shows!!!
Laars, Damn Laars, and Statisticians...
Is what Mark Twain once said. Maybe he meant "Liars" instead of Laars.
Nice work Moses. Pleasure meeting you and Kal last month.
Regards,
PR0
- 167 Indoor-Air Quality
