Andrew Hagen Laing Question
Rob_34
Member Posts: 21
..could answer a question for me? Can you disconnect the third heating element so that you can use a lower amperage breaker? Could have used only the EPR 9 but all they have is the EPR 15 and I really want to install one on this project. Time is a factor and I couldn't wait for the smaller units to arrive.
Rob Blair
Rob Blair
Yes
Yes you can disable an element. You can also use the elements in stages so that they come on one after the other as needed. Some parts of the Laing instructions are a little difficult to understand. On page 17 it says you can open jumper 6 or 7 to disable elements 2 or 3.0 -
Question
I 'm not sure that you are allowed to "downsize" the circuit breaker/wire size, because of the"what if"senerio! What if in the future someone wants to reconnect the "extra " heater? The N.E.C. C/B and wire sizing is based on "name tag information" .Disconnecting a heater is one thing ,as Andrew say's.Wire, C/B size is a different matter0 -
Techman, I totally understand where you are coming from. I had those thoughts immediately!
Thanks,
Rob0 -
That's okay Andrew, I was just doing a heatloss and realized that I needed alot more than I thought for the btu output. This is for a floor warming around an indoor lap pool so the slab will need to be alot warmer than usual.
Thanks,
Rob0
