solar hookup to existing boiler loop
Frank_63
Member Posts: 40
this situation seems to fall between plumbing, boilers and solar. i want to hook a solar evacuated tube array into an existing boiler loop. i need a 1 1/2" mixing valve that will check the solar array water temp and use that if hot enough and if not, call for heat from the boiler to supplement solar array. I have a taco zvc 406 that is running all my zone valves in the existing boiler loop ( hydronic floor, dhw, endless pool). can you tell me if such a creature exists and if so, can i run it with my existing controller? thanks alot for your help
The ? you should be asking is do I want to shoot 200-400 degree water into my boiler loop. You need to either add a mixing control( my least favorite idea) or you need to add a storage tank to buffer down to a usable temperature. Then you can ask the other question and the answer is yes with a Tekmar control.0 -
OR.....
You could run a seperate baseboard loop or radiant panel so you could run it at the same time as your boiler loop. You will harvest a lot more energy. Low temperature energy.
Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
