Becket heat manager fail?
lee_7
lee_7 Member Posts: 457
waranty is with Heat master, not installer. installer might have a labor warranty, but if he is out of business, you might be stuck with labor part of bill
  • TimS
    TimS Member Posts: 82
    Beckett heat manager fail?
    It seems like the heat manager has seemed to have failed. Worked for a few months,.installed at the end of last season. Boiler works fine when you switch it to off.
    The heating guy says it might be the sensor or the unit itself. Is there an easy way of checking which? (I don't think you can go to the local supply store and get a sensor.) Oil company installer last year is out of business...
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    There's
    a 5 year warranty.
  • Hollis
    Hollis Member Posts: 105
    How would you go about getting help on this if the installer is out of business?......
  • Robert O'Brien
    Go to the Beckett heatmanager website and find a local installer.They should be able to help you out
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Sensor
    Sensors are sold seperatly..Have them on the shelf..
  • Robert O'Brien
    Of course
    "you might be stuck with labor part of bill" And the alternative is?
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    what is wrong that you think it seemed to have failed ?? do a search for heat manager --go to Becketts site and check out the troubleshooting guide
  • Leo_22
    Leo_22 Member Posts: 6
    Who does
    Who now does your service? You should have someone you deal with and they should be able to get parts.
    Leo
  • Hollis
    Thank you guys,
    I got a sensor and I'll try it.
    as to why I think it failed, burner won't run with it switched on, when I change the switch it does. Printed out the trouble shoot from the site, I'll sit down and read it in the morning to see if I can glean anymore information.
