Psychrometrics Chart downloads
http://www.arch.hku.hk/~cmhui/teach/65156-7e.htm
Glenn Stanton
Manager of Technical Development
Burnham Hydronics
U.S. Boiler Co., Inc.
Glenn Stanton
Burnham Hydronics
Psychrometrics Chart Downloads
Do any of you pro's know were i can download a Psychrometrics Chart as i am in need of training some canadian contractors.Thanks in advance. Kim0 -
Do you need them for a particular
altitude or temperature range? Let me know. I may be able to make some up for you in PDF format."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Psychrometric charts
Thanks for the reply i am from Vancouver canada
and was hoping to get a chart in excel format,if there is one out there.
i need it to show the following:
wb and dew point temp - 35 to 90 degree f
db temp - 35 to 105 degree f
weight of water vapour in one pound of dry air(grains)
from - 0 to 180
total heat -btu.per pound dry air from - 13 to 48
sensible heat percentage of total capacity from - 40 to 100
along with wet bulb lines relitive humidity
and cu. ft per lb of dry air
hope this helps .
thanks kim
try..
handsdownsoftware.com. They have a bunch of stuff that might be of help to you.0 -
Kim-
I will see what I can do. I tried printing my Psychrometric charts via Adobe Acrobat Distiller but it did not "stick".
By the way, I use a couple of programs, principally Elite Software's PsyChart which runs about $200 and Linric (linric.com as if you did not know
has a line of prodcuts including a psychrometric calculator as well as an Excel database of psychrometric data points.
Not sure if you need graphic or tabular data, but see if they have something closer to what you need.
I will keep trying at my end and if I succeed, post them here.
Brad"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
Great site!
Never heard of them before; they are bookmarked now. Thanks!"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
Call the local Trane office
Kim- I'm in Vancouver- we have pads of 8-1/2x11 psych charts we got from the local Trane sales office in Burnaby - call them and see if they have any hiding in their back room of "engineer's graft". Great for doing the design then filing the marked up chart into the file. A bit small, but it can be read and a whole pad will last a while.0 -
I agree, Geoff
I got the 8-1/2 x 11 pads and the really great 11x17 pads. High quality engraved printing... hard to get. I covet mine. No you cannot have any.
Carrier
Willis Haviland Carrier who invented it sells a neat heavy laminated one. You can write on it(pencil) and erase. It's about 12 by 18? When I bought mine I think they were about $2.00. Any Carrier dist. should have them.0 -
Bigger Pads??!!
They've been holding out on me! All I get are these little 8-1/2 x 11 pads and they have bigger pads? Well, maybe on threat that I erase Trane from my "equals list", I'll get some action.....0 -
E-Mail Me
Off-Line, Geoff, if you have no luck...
For you, I will see what I can spare. But try Trane first. Tell them you will sic Ned Morris from the Tucson office on them if they do not comply. Shameless name-dropper am I.
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
