Help with \"Infloor\" radiant system
Nron_13
Nron_13 Member Posts: 164
How about a picture posted since ther are no rating plates and a discription of what is wrong with the radiant heating will help
  • John_108
    John_108 Member Posts: 21
    I am trying to find some information on an "Infloor" radiant pump control unit. This unit has two supply inlets and two return outlets with a grunfoss pump and a controller that shows the water temp and has low voltage electrical connections. There was no model number on this device, and I could not find any info on the "Infloor" website. This boiler system is piped completely wrong and we are working to repipe the system and I would like to have some information on how this controller works.
    Thanks,
    John
  • S Davis
    S Davis Member Posts: 491
    Infloor
    Take it out if you can, alot of those units around here failed and sent boiler temp water into the radiant floors damaging alot of floor coverings.
    the only problem is a lot of times they are remote from the boiler and the lines were sized for high temp.
    S Davis
    Apex Radiant Heating
