Help with \"Infloor\" radiant system
Nron_13
Member Posts: 164
How about a picture posted since ther are no rating plates and a discription of what is wrong with the radiant heating will help
I am trying to find some information on an "Infloor" radiant pump control unit. This unit has two supply inlets and two return outlets with a grunfoss pump and a controller that shows the water temp and has low voltage electrical connections. There was no model number on this device, and I could not find any info on the "Infloor" website. This boiler system is piped completely wrong and we are working to repipe the system and I would like to have some information on how this controller works.
Thanks,
John0 -
Infloor
Take it out if you can, alot of those units around here failed and sent boiler temp water into the radiant floors damaging alot of floor coverings.
the only problem is a lot of times they are remote from the boiler and the lines were sized for high temp.
S Davis
Apex Radiant Heating0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
