droping the water-line
Steamhead (in transit)
Member Posts: 6,688
some pictures of the boiler in question.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have a job with a steel tube boiler (steam). the boiler has a very small steam chest and is piped to the old header-less riser. I would think under this boiler is the old one and so is the best place for the for the water-line. All of the classic mastakes have been made on this job and forthe last few years it has been worse as per the owner. Being one of Dan's decipales I started with the pressuretrol and venting. Another thing i want to do is drop the feeder to give me a little more A dimention (loose the street 90's on the 47). What i am asking is that i really like to lower the feeder even more to make for a better steam chest and more A dimention, enough to put the top row of tubes above the water-line. I'm sure that the boiler will still make steam less those tubes, but will i cause other problems? thanks tommyc0 -
Water lines
are established by the manufacturer for a reason. If you want a new boiler .... exposing tubes is a good place to start.
Don't do it!0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
