droping the water-line
some pictures of the boiler in question.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • tommyc
    tommyc Member Posts: 3
    I have a job with a steel tube boiler (steam). the boiler has a very small steam chest and is piped to the old header-less riser. I would think under this boiler is the old one and so is the best place for the for the water-line. All of the classic mastakes have been made on this job and forthe last few years it has been worse as per the owner. Being one of Dan's decipales I started with the pressuretrol and venting. Another thing i want to do is drop the feeder to give me a little more A dimention (loose the street 90's on the 47). What i am asking is that i really like to lower the feeder even more to make for a better steam chest and more A dimention, enough to put the top row of tubes above the water-line. I'm sure that the boiler will still make steam less those tubes, but will i cause other problems? thanks tommyc
  • The Boiler Dr.
    The Boiler Dr. Member Posts: 163
    Water lines
    are established by the manufacturer for a reason. If you want a new boiler .... exposing tubes is a good place to start.
    Don't do it!
