Radiator in basement
Scot_4
Scot_4 Member Posts: 6
Install a radiator in the boiler room?
I have a one pipe parallel flow dry return system with a very tall boiler, wood gun,. One take off, with two dry returns. Would it be easy to heat the basement with a radiator off this current system and how would i tie it in?
I finished insulating my drop header and returns so now my boiler room/workshop is colder than I'd like it. Need heat..... it's freakin cold here man.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    You might.......
    want to read this:
    http://www.heatinghelp.com/newsletter.cfm?Id=29
    Could be the solution you need.
  • Scot B
    Scot B Member Posts: 26
    thanks... will take a look.
  • Dale
    Dale Member Posts: 1,317
    basement ceiling
    The old places sometimes had a radiator horizontal on the ceiling, pitch it right and it will work. Or, just get some fin tube in the joist spaces and make a condensate system.
