Radiator in basement
Scot_4
Member Posts: 6
Install a radiator in the boiler room?
I have a one pipe parallel flow dry return system with a very tall boiler, wood gun,. One take off, with two dry returns. Would it be easy to heat the basement with a radiator off this current system and how would i tie it in?
I finished insulating my drop header and returns so now my boiler room/workshop is colder than I'd like it. Need heat..... it's freakin cold here man.
You might.......
want to read this:
http://www.heatinghelp.com/newsletter.cfm?Id=29
Could be the solution you need.There was an error rendering this rich post.
thanks... will take a look.There was an error rendering this rich post.
basement ceiling
The old places sometimes had a radiator horizontal on the ceiling, pitch it right and it will work. Or, just get some fin tube in the joist spaces and make a condensate system.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
