rugs suitable for use on hardwood and cork floors with radiant ?
realolman
realolman Member Posts: 513
use carpet or rugs with radiant heat???
  • Susan Johnson
    Susan Johnson Member Posts: 9
    I read that I should not put tightly woven wool rugs on my radiant heated hardwood and cork floors. What kind of rugs can be used? Sources for these rugs?
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Ive always been a big fan of bear rugs,.. the ones with the heads and teeth still attatched.
    Sorry, couldnt resist :)
  • Ruthe Jubinville_2
    Ruthe Jubinville_2 Member Posts: 674
    carpet
    you can use carpet but it is the type padding or backing that prevents the heat from working as well, I believe.
    Ruthe
  • Ron Gillen
    Ron Gillen Member Posts: 124
    Output Graphs for Floor Coverings
    If this link works, it shows output of various floor coverings. http://www.heatlink.ca/pro/download.asp?filename=L2301.pdf
  • Constantin
    Constantin Member Posts: 3,796
    Hmmm...
    ... any insulation you plave on top of the floor will reduce the heat transfer, therefore reduce the output of your RFH system. A foam layer underneath the carpet (a good idea re: longevity) will only increase the insulative effect. I've been told that the following two suppliers are worth considering re: layers under carpets:
    Sponge Cushion
    902 Armstrong Street
    P.O. Box 709
    Morris, Illinois 60450
    1-800-435-4062
    Fax: 800-423-3557
    http://www.sponge-cushion.com
    Foamex
    1000 Columbia Avenue
    Linwood, PA 19061-3997
    Executive Offices
    Tel 610-859-3000
    or 1-800-776-3626
    Fax: 800-355-3626
    http://www.foamex.com
    We used the foamex product under a wall-to-wall plush carpet in the basement, and I have to say that the room heats great. However, a well-insulated slab is also about the least worrisome RFH system to put a carpet + foam onto. If you use something like suspended tubes that have a very limited output, beware!
