false water line
jackchips_2
Member Posts: 1,337
Gordo.
By the way, is that your lunch (dole) heating up in number 12?
Jack
Jack
False water line
I have a problem with slow returns on a 175 HP boiler. The boiler is fairly new. Its one pipe steam. I want to install a boiler feed tank but I cannot install steam traps on all the drip lines. I want to build a false water line as mention in the Lost Art of Steam Heating. Is this possible with a boiler of this size?0 -
Yes.
Retired and loving it.0 -
I have done this Quite a few times as per, Lost Art including removing a couple of condensate pumps that shouldn't have been there in the first place. One or two, as I recall were of the'"if it doesn't work you don't have to pay me" variety. It works like a charm. They paid.0 -
False Water Line
Here is one I put in to keep wet returns wet.
Magnificent Work Gordo
Nothing short of magnificent."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Jack
That is a Dole vent, silly! The inverted bucket kind.
Pressure builds, she vents. Easy.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
