false water line
jackchips_2
jackchips_2 Member Posts: 1,337
Gordo.
By the way, is that your lunch (dole) heating up in number 12?
Jack
  • Joe D
    Joe D Member Posts: 3
    False water line
    I have a problem with slow returns on a 175 HP boiler. The boiler is fairly new. Its one pipe steam. I want to install a boiler feed tank but I cannot install steam traps on all the drip lines. I want to build a false water line as mention in the Lost Art of Steam Heating. Is this possible with a boiler of this size?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,730
    Yes.
    Retired and loving it.
  • laurence salvatore_2
    laurence salvatore_2 Member Posts: 86
    I have done this Quite a few times as per, Lost Art including removing a couple of condensate pumps that shouldn't have been there in the first place. One or two, as I recall were of the'"if it doesn't work you don't have to pay me" variety. It works like a charm. They paid.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,689
    False Water Line
    Here is one I put in to keep wet returns wet.
  • Brad White
    Brad White Member Posts: 2,399
    Magnificent Work Gordo
    Nothing short of magnificent.
    -Ernie White, my Dad
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Jack
    That is a Dole vent, silly! The inverted bucket kind. :)
    Pressure builds, she vents. Easy.
