adding a radiator
mario & luigi
Member Posts: 11
I'm all for homeowners giving things a shot but this is level 9 do it yourselfer. However, if you have a wet return down low you might pipe it through a radiator and heat this room
adding a radiator
single pipe system steam heat. I have one room in basement that is not heated. 2 other rooms are with radiators fixed to the ceiling. how do i go about installing a radiator to the unheated room. the boiler is basically on the other side of the wall0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
