reverse thread pipe nipples to connect radiators
Steve Adamczyk
Member Posts: 2
I'm in Milwaukee,Wi. I need to disconnect several radiators. The problem is that the return end does not have a union. They use a pipe nipple and elbow that are reverse threaded. I have used these before, however the supply house where I got them is no longer in business.
Any suggestions on where I can get these.
The nipples are 1 1/4" x 3" black pipe.
Thank you,
Steve Adamczyk
Thank you,
Steve Adamczyk
pex supply --they got 'em
Click here: PEX Tubing - Wirsbo Radiant Heat - Taco Pumps - Radiant Floor Heat - PEX Plumbing Supplies0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
