reverse thread pipe nipples to connect radiators
I'm in Milwaukee,Wi. I need to disconnect several radiators. The problem is that the return end does not have a union. They use a pipe nipple and elbow that are reverse threaded. I have used these before, however the supply house where I got them is no longer in business.
Any suggestions on where I can get these.
The nipples are 1 1/4" x 3" black pipe.
Thank you,
Steve Adamczyk
