6\" Baro on 5\" Flue
Steamhead (in transit)
Member Posts: 6,688
generally fit the next size smaller pipe rather well. We find we need to do this a lot in older buildings with chimneys designed for coal boilers. Try dry-fitting it first before getting a custom piece made up.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Mounting Draft Regulator
I see that for tall chimneys, Field controls recomends a larger flue damper. Say 6" instead of 5". How do you put a 6" barometric on a 5" flue pipe? Do they fit right or will I end up with a bunch of crumpled sheet metal.
Also, Am I better off with an RC or type M?
Or, should I just put two 5" RC's on? They don;t make the M in 5".0 -
Use an "M", better in my opinion. YOU will either need to find a 5x6x5 tee or use a5" piece of pipe and use adapter in draft regulator box to cut into pipe.0 -
Ok.
I have to get some custom duct work done and perhaps they can make me a T. I was looking at the (probably 50 year old) install manual for the M control and I don't think that the collar will bend to size very well.0 -
Use the collar supplied, go with M, the latest cheapo regulators I've seen are incredibly cheap. Field's performance is based on the size/design of the collar, a tee in place of their collar is not recommended. Box usually states sizing 6" regulator will fit 5-6-7 pipe.0 -
Thanks
Finaly had the steely eyed boiler man out today. Draft measured -.04 WC and +03 over fire.. Hmmm. Its running ok. I have a FIC I need to install but that flapper is bugging me. My 6" M came and it was a bit out of round so it sticks. I bent it into shape but why does everything Field make seem a bit hacked? I put the restrictor in the FIC tonight and I needed to use a hammer and block??? It still won;t sit all the way down. Grrrrr...0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
