a new one for BillW@Honeywell
carol_3
Member Posts: 397
Hey Bill, do you know the answer to this one?
R7184- low voltage damage
Hello, During a storm a home encountered a low voltage condition. The R7184 and the Beckett igniter were damaged. Is there a minimum voltage where the controller will not switch the line voltage to the igniter? Both Honeywell and Beckett could not help me there. Beckett said anything under 80 volts will do damage. If there is no safeguard, maybe there should be. At least it would save one component. Thanks, Spark
Well, here's an idea...
I have always been a proponent of installing whole-house surge supressors to protect all the electronic gizmos we depend on today, and not just for heating & cooling. Ligtning transients do funny things to electrical systems, as does utility load switching. Brownouts regularly fry AC compressors, low voltage cooks zone valve motors, so I would assume that the same would happen to an oil primary. I will forward this to the combustion gurus to see what they have to say. See you at NAOHSM!0 -
Thanks Bill. Yep, NAOHSM. I'm ready for May.0 -
voltage and amps
If voltage drops, don't the amps increase for the load if it's drawing? possibly an amperage overload is burning out the relays or transformers. Grainger sells over and under voltage cut-out relays that reset when voltage returns to normal. just a thought. Also, check the posting on "voltage drop" down bottom in "Ask the professor"0
- 50 Industry Classes
