Stat recommendations??
I need to find a good digital stat that will operate with Taco three wire zone valves. Any suggestions?
  • Andrew Hagen
    Andrew Hagen Member Posts: 15
    3-wire
    You mean you don't want those 70's style White Rodgers thermostats? ;-)
    They also have a digital version.
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Honeywell Focus Pro 5000
    is the way to go. Small stat, battery operated or can have a common wire connected, can be configured for a heating only system and use of 2, 3, 4, or 5 wire zone valves.
    Just make sure you set the cycle rate for 3 when your in the installers setup.
