Banging Pipes
bob young
Member Posts: 2,177
air chambers or anti-knock coils
Banging Pipes
Is there something I can install on my hot and cold pipes to stop the banging when closing the taps?0 -
Check for loose
faucet washers first. If OK, you may need a pressure reducing valve to cut back the incoming water pressure.0 -
Banging
How long should the air chamber be and which size pipe to use??0 -
air chambers
same size as related piping and 18 " long with cap. if in accessable location provide pet cock to service and bleed to replenish cushon if necessary.0
- 167 Indoor-Air Quality
