Banging Pipes
bob young
bob young Member Posts: 2,177
air chambers or anti-knock coils
  • Paul_28
    Paul_28 Member Posts: 113
    Banging Pipes
    Is there something I can install on my hot and cold pipes to stop the banging when closing the taps?
  • RonWHC
    RonWHC Member Posts: 232
    Check for loose
    faucet washers first. If OK, you may need a pressure reducing valve to cut back the incoming water pressure.
  • Paul_28
    Banging
    How long should the air chamber be and which size pipe to use??
  • bob young
    air chambers
    same size as related piping and 18 " long with cap. if in accessable location provide pet cock to service and bleed to replenish cushon if necessary.
