Ha Dan Primary Secondary Problem
Mitch_6
Member Posts: 549
Show Two boilers tied into the Primary loop one after another. In a Two boiler install with a Tekchmar staging control this seems to work OK since not all the time both boilers fire.
I have a case were four boilers are tied in like this and the last boiler receives so much temperature from the prior three on peek demand that it barely fires.
It seems tying all the feeds together then all the returns together then going in the the primary is a better way.
Just my observation.
Mitch S.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=388&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Mitch S.
Sorry \"HAY\" DAN could not go back and edit the title
I agree.
That's the best of the two options, and I think I have that in the Made Easy book, but I don't have a copy here to check. Thanks.Retired and loving it.0 -
Yes Page 111 of Made easy shows this
Unfortunately we did a job using page 111 of pumping away about three years ago. Using four boilers.
Live and learn.
Mitch S.
- 167 Indoor-Air Quality
