boiler full of water
midway_2
midway_2 Member Posts: 42
Someone filled the 1 pipe steam boiler with water, glass tube on the side has water all the way to top, don't know how much is in there. We have been usually putting in about an inch each cold day to bring it up to the mark on the tube, but someone has over did it, Will it still work, or do we have to shut down and drain. What would happen if it isn't drained down to the mark on the glass tube? (may be a crazy thought,BUT, could it explode?) can you tell I'm not a steam man? LOL
