Burnham base ray radiator
steven E.HEAT
Member Posts: 47
how long is this section of base-ray?????????
I have Burnham base-ray radiators in my house, which i have owned for 7 years....they work great with the exception of one in our family room which is slowly leaking water out along what looks like a seam...started out as rust spot but has now progressed to slowly leaking...have emailed company yesterday in regards to finding a contractor in my area (Tewksbury MA - north of boston) but have received no answer..would my regular oil burned contractor be able to fix this or can someone lead me to someone in my area?? any help/guidance is appreciated..john0 -
sounds like
Sounds like the push nipples are going bad. Very replaceable... Sorry I'm way out of your area. Make sure you get a real boiler pro to do the job.... Those cast iron radiators are considered the 2nd best for heat and comfort....0 -
John
The nipples that connect the various sections of Baseray baseboard together are indeed replaceable. This can occur after a period of time as buildings settle a bit. I would check with your own company first about this. We can hook them up with a local source in the Boston area for the nipples as well as a tool to draw the sections together. I will be with some of our Boston area representatives tomorrow and will ask about contractors in your area that have worked with the Baseray. I'll keep in touch when I get back tomorrow night or Wednesday.
Glenn Stanton
Manager of Technical Development
Burnham Hydronics
U.S. Boiler Co., Inc.0 -
info??
Glenn, just wondering if you have any info yet...thanks0 -
this particular section is where two 3 foot sections have been joined together as part of a larger 20 foot section.
section
this is leaking between two 3 feet sections which is part of a larger section which measures 20 feet long.0 -
the long run is the problem . been there done that it stinks. you need to break it into 2 sections wa valve enclosure in between.cast iron bb dont like long continous sections . i try not to exceed 12 feet per section.0 -
I'd give Bobby Gagnon in Lowell a call He's one of the best in your area . And I'd agree Base ray is an Excellent radiator.0 -
thanks
thanks all for your imput and to Glen Stanton I did get your email - Thank you very much for your info..tried to email you but kept coming back..Thanks again John0
- 167 Indoor-Air Quality
