Burnham base ray radiator
steven E.HEAT
steven E.HEAT Member Posts: 47
how long is this section of base-ray?????????
  • John F_3
    John F_3 Member Posts: 3
    I have Burnham base-ray radiators in my house, which i have owned for 7 years....they work great with the exception of one in our family room which is slowly leaking water out along what looks like a seam...started out as rust spot but has now progressed to slowly leaking...have emailed company yesterday in regards to finding a contractor in my area (Tewksbury MA - north of boston) but have received no answer..would my regular oil burned contractor be able to fix this or can someone lead me to someone in my area?? any help/guidance is appreciated..john
  • sounds like
    Sounds like the push nipples are going bad. Very replaceable... Sorry I'm way out of your area. Make sure you get a real boiler pro to do the job.... Those cast iron radiators are considered the 2nd best for heat and comfort....
  • John
    The nipples that connect the various sections of Baseray baseboard together are indeed replaceable. This can occur after a period of time as buildings settle a bit. I would check with your own company first about this. We can hook them up with a local source in the Boston area for the nipples as well as a tool to draw the sections together. I will be with some of our Boston area representatives tomorrow and will ask about contractors in your area that have worked with the Baseray. I'll keep in touch when I get back tomorrow night or Wednesday.
    Glenn Stanton
    Manager of Technical Development
    Burnham Hydronics
    U.S. Boiler Co., Inc.
  • John F_3
    info??
    Glenn, just wondering if you have any info yet...thanks
  • Dave_4
    Dave_4 Member Posts: 1,404
    this particular section is where two 3 foot sections have been joined together as part of a larger 20 foot section.
  • Dave_4
  • Dave_4
    section
    this is leaking between two 3 feet sections which is part of a larger section which measures 20 feet long.
  • steven E.HEAT
    the long run is the problem . been there done that it stinks. you need to break it into 2 sections wa valve enclosure in between.cast iron bb dont like long continous sections . i try not to exceed 12 feet per section.
  • Lyle C
    Lyle C Member Posts: 96
    I'd give Bobby Gagnon in Lowell a call He's one of the best in your area . And I'd agree Base ray is an Excellent radiator.
  • John F_3
    thanks
    thanks all for your imput and to Glen Stanton I did get your email - Thank you very much for your info..tried to email you but kept coming back..Thanks again John
