Hot Rod/Caleffi Solar school
Rich Kontny_3
Member Posts: 561
Is Niagara, WI I worked on an elementary school there in 1978. Back then you had to watch where you stayed. I had a room that was 20 ft away from the rail lines. A train full of iron ore went past at three in the morning.
Also this is the UP of Michigan where the infamous "Yuppers" come from. Design Air is a class operation, part of US Oil based in Combined Locks, WI. My guess is that you will have to register through them.
Rich
Rich
Hot Rod/ Caleffi Solar school
Hi Bob,
I just registered today for one of your solar heating classes, that is sponsored by Design Air. Class in Iron Mountain, on May 6th. Look forward to meeting you. :-)
Ross0 -
Iron Mountain?
Michigan?0 -
...yep
Iron Mountain, MI. Short drive from Marquette! :-)
Should be a good time. Usually, a lot of Design Air's classes are in Kimberly or Milwaukee, so when they are a little closer to home for us, we try to take advantage.
Ross0 -
Will I still need snow tires?
See you there, we will have a good time.
hrBob "hot rod" Rohr
By that time...
probably not, but in the U.P. of Michigan, you never know. :-)0 -
Caleffi
will send you the video of Hot Rod installing a Caleffi Solar system for free. Just go to their website and email them.
Alan, I sit corrected (apparently others here prefer to stand while being corrected) I for one, do not.
Ahem. For free, Caleffi will send you the video of Hot Rod installing one of their solar thermal systems (hopefully for pay).
"Opportunities are never lost, someone will take the ones you miss."0 -
Is that school open to customers of Design Air only or can anyone attend? If open where does a person register?0 -
Design Air
I'm not sure, Steve. You'd probably have to call & find out.
www.designair.com
Hot Rod
installs solar systems for free?0 -
spelling
Sorry Richard,
I have to correct your spelling. It's "Yoopers" :-)0 -
Senior moment
I stand corrected0
- 167 Indoor-Air Quality
