Hot Rod/Caleffi Solar school
Rich Kontny_3
Rich Kontny_3 Member Posts: 561
Is Niagara, WI I worked on an elementary school there in 1978. Back then you had to watch where you stayed. I had a room that was 20 ft away from the rail lines. A train full of iron ore went past at three in the morning.
Also this is the UP of Michigan where the infamous "Yuppers" come from. Design Air is a class operation, part of US Oil based in Combined Locks, WI. My guess is that you will have to register through them.
Rich
  • Ross_7
    Ross_7 Member Posts: 577
    Hot Rod/ Caleffi Solar school
    Hi Bob,
    I just registered today for one of your solar heating classes, that is sponsored by Design Air. Class in Iron Mountain, on May 6th. Look forward to meeting you. :-)
    Ross
  • S Ebels_2
    S Ebels_2 Member Posts: 74
    Iron Mountain?
    Michigan?
  • Ross_7
    ...yep
    Iron Mountain, MI. Short drive from Marquette! :-)
    Should be a good time. Usually, a lot of Design Air's classes are in Kimberly or Milwaukee, so when they are a little closer to home for us, we try to take advantage.
    Ross
    hot_rod Member Posts: 26,607
    Will I still need snow tires?
    See you there, we will have a good time.
    hr
  • Ross_7
    By that time...
    probably not, but in the U.P. of Michigan, you never know. :-)
  • Caleffi
    will send you the video of Hot Rod installing a Caleffi Solar system for free. Just go to their website and email them.
    Alan, I sit corrected (apparently others here prefer to stand while being corrected) I for one, do not.
    Ahem. For free, Caleffi will send you the video of Hot Rod installing one of their solar thermal systems (hopefully for pay).
    "Opportunities are never lost, someone will take the ones you miss."
  • S Ebels_2
    Is that school open to customers of Design Air only or can anyone attend? If open where does a person register?
  • Ross_7
    Design Air
    I'm not sure, Steve. You'd probably have to call & find out.
    www.designair.com
  • Hot Rod
    installs solar systems for free?
  • Ross_7
    spelling
    Sorry Richard,
    I have to correct your spelling. It's "Yoopers" :-)
  • Rich Kontny_3
    Senior moment
    I stand corrected
