Pipe Joint Insulation
David Nadle
David Nadle Member Posts: 624
They make PVC formed covers for elbows & tees. They come with a fiberglass "diaper" you wrap around the fitting, then you seal the cover on with tape. The come sized for the O.D. of your insulation; a good source will have a sizing chart available.
  • dennis8
    dennis8 Member Posts: 15
    Hi,
    I am a homeowner with steam boiler and the pipes in the basement are not insulated. I am planning on using fiberglass pipe insulation to cover the pipes. Would like to see what you recommend for the elbow joints. A few people have suggested a brush on acrylic or cement that could be used on the elbow joints and also be used to seal the fiberglass. I am a little confused about this and would appreciate any suggestions.
    Thanks
    Dennis
  • or you can use
    Cold water paste with cheese clothes to form around fittings, etc
  • Jason_44
    Jason_44 Member Posts: 60
    What is a good source for these?
    Jason
  • dennis8
    pvc covers
    You can get the pvc covers here
    http://www.mcmaster.com/ page 3420
  • David Nadle
    I like buyinsulationproducts.com
