Pipe Joint Insulation
David Nadle
Member Posts: 624
They make PVC formed covers for elbows & tees. They come with a fiberglass "diaper" you wrap around the fitting, then you seal the cover on with tape. The come sized for the O.D. of your insulation; a good source will have a sizing chart available.
Hi,
I am a homeowner with steam boiler and the pipes in the basement are not insulated. I am planning on using fiberglass pipe insulation to cover the pipes. Would like to see what you recommend for the elbow joints. A few people have suggested a brush on acrylic or cement that could be used on the elbow joints and also be used to seal the fiberglass. I am a little confused about this and would appreciate any suggestions.
Dennis0 -
or you can use
Cold water paste with cheese clothes to form around fittings, etc0 -
What is a good source for these?
Jason0 -
I like buyinsulationproducts.com0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 954 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
