American Standard hotwater baseboard installation question
Tom Elam
Member Posts: 57
The fins on the copper pipe are rectangle. Some were installed with the longer side vertical and some are horizontal. Installed horizontally the fins fill the area between the back and front panels. Installed vertically there is about a half inch gap between the fins and covers.
How much of a differance does it make in the baseboards output? Would it be worth the time and trouble to turn the pipe 90° to fill the gap?
I'd say
output is the same either way since they both expose the same amount of surface area to the air as it's passing by.
If you look straight down from top, the fins that you can see thru are installed correctly. The others can, possibly, be turned on pipe to correct location. Most fins are loose on pipe and can be twisted. Carefully, with gloves on as fins are like little razors, start at one end and turn fins. There should be no need to cut pipe or drain water.0 -
OK, Thanks for the replies. I may try to turn the fins 90°.0 -
fin orientation
It seems to me (this is a WAG) that if the fins are in the vertical orientaion, they will more efficiently produce the desired convection currents that are the motive force for heat distribution in finned baseboard radiation. I doubt that it will make a huge difference but for the few minutes of your time that it will take to turn them all to vertical, it might save you a couple of bucks.0
- 167 Indoor-Air Quality
