Frank
Kara
Kara Member Posts: 36
Thanks Brad!
  • Kara
    Iron vs Steel for 1pipe steam
    hi All.
    Dan's book talks about using steel piping for steam heating. Pex supply carries only iron couplings and elbows.
    will they work just as good?
    Thanks
  • Brad White_203
    Brad White_203 Member Posts: 506
    If I may...
    Same thing by different names. Colloquially, they are all termed "iron pipe". The pipe is actually carbon steel (ASTM A53, usually Sch. 40) and the fittings are what are really iron, usually gray cast iron or malleable iron.
