sealant
Al Letellier_9
Member Posts: 929
Because it's so hard to find cast iron fittings and having to use malleable ones instead, I use wide teflon (couple of wraps) and then a good quality pipe dope. That fitting will come apart later on if need be. Have installed several Smith Mills "porkchops" using Never Seize for pipe dope and that works very well indeed.
what is best to seal near boiler pipe joints for steam heat?0 -
48\" pipe wrench.
