rugs suitable for use on hardwood and cork floors with radiant ?
realolman
Member Posts: 513
use carpet or rugs with radiant heat???
I read that I should not put tightly woven wool rugs on my radiant heated hardwood and cork floors. What kind of rugs can be used? Sources for these rugs?0 -
Ive always been a big fan of bear rugs,.. the ones with the heads and teeth still attatched.
Sorry, couldnt resist
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
carpet
you can use carpet but it is the type padding or backing that prevents the heat from working as well, I believe.
Ruthe0 -
Output Graphs for Floor Coverings
If this link works, it shows output of various floor coverings. http://www.heatlink.ca/pro/download.asp?filename=L2301.pdf0 -
Hmmm...
... any insulation you plave on top of the floor will reduce the heat transfer, therefore reduce the output of your RFH system. A foam layer underneath the carpet (a good idea re: longevity) will only increase the insulative effect. I've been told that the following two suppliers are worth considering re: layers under carpets:
Sponge Cushion
902 Armstrong Street
P.O. Box 709
Morris, Illinois 60450
1-800-435-4062
Fax: 800-423-3557
http://www.sponge-cushion.com
Foamex
1000 Columbia Avenue
Linwood, PA 19061-3997
Executive Offices
Tel 610-859-3000
or 1-800-776-3626
Fax: 800-355-3626
http://www.foamex.com
We used the foamex product under a wall-to-wall plush carpet in the basement, and I have to say that the room heats great. However, a well-insulated slab is also about the least worrisome RFH system to put a carpet + foam onto. If you use something like suspended tubes that have a very limited output, beware!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
