Rinnai, Takagi or Bosch tankless???
tim smith
tim smith Member Posts: 2,886
Any favorites or reservations, looking for opinions. Thanks Tim.
  • Spudwrench
    Spudwrench Member Posts: 47
    Tankless HW heaters
    I like the Takagi. It's microprocessor controlled (some of the Bosch ones aren't and use a mechanical system to modulate the burner- it's just not as slick.) Also, some of the Bosch models allow for conventional chimmney venting, which to me implies less efficient heat exchangers.
    FYI, I am a homeowner and my information on the Bosch may be out of date. Just my two cents. My Takagi has been great.
    Nathan
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,378
    We have a few Rinnai's out there.....
    performing well and no call backs. Mad Dog
  • John_108
    John_108 Member Posts: 21
    I have installed both. I prefer the Rinnai over the Takagi. The Takagi has to be manually reset after a power outage unless you install a battery back up, the Rinnai will auto reset. I also like the Rinnai's flue termination (concentric cone shaped) to the Takagi"s which requires a 12 x 12 hole for the stainless steel termination box. Both ran great no problems 2-1/2 years. Watch if they are on a well. They will need to be de-scaled every year.
  • Tony_23
    Tony_23 Member Posts: 1,033
    My 2 cents
    Stay away from Bosch...
    Takagi's good, Rinnai's better, Noritz also better.
